S40 T5, 2004, Krchan Pojdi na stran
[4]
5
6
7
8
9
10
Volvo. 4 life | 10 jul 2009, 14:42 | |
| reds40t5 je napisal(a): ...
...po moje je to malo za lese privlečeno, ali pač?
Sem ti napisal, + 5 HP! Pri tvoji/naših konjenicah potrebuješ vsaj + 30 HP ( ampak REALNIH hp ), da se kaj pozna. Ko sem jaz naredil 3" DP, pa kat. dal stran v pospeških ni bilo razlike, sem mislil da sem stran vrgel 400€, potem se pa s 4 ljudmi v avtu peljem v Vrhniški klanec, ali Črni kal .... potem pa mi je bilo takoj jasno, da avto " lažje diha " | Na vrh | |
Krchan | 10 jul 2009, 15:44 | |
| Se mi je zdelo, da je 14 HP mal huda. Predvsem se mi pa gre za boljši zvok, kakšnega konjička ekstra se pa tudi ne bom branil. Daj mi še na kratko povej, kakšen je postopek pri chip tuningu z firmo Hi-tuning. Moraš iti z avtom na "sever", ali kako drugače (pošljejo po pošti...). Sem malo bral tvoje poste, pa nisem našel, da bi kje omenjal postopek. | Na vrh | |
Mihc V50 T5 | 10 jul 2009, 15:50 | |
| Mislim da pri Evolvu niso spreminjali filtra zaradi računalnika. usaj jaz sem tako razumel besedilo.
ECM Cooling. The ECM (Electronic Control Module) is the computer that controls all engine management functions. In stock trim, the ECM is mounted to the factory air box. The back side of the ECM is finned for cooling, and these fins protrude through a window in the air box to expose it to filtered air being drawn into the engine. A simple, effective, ingenious design by the factory to cool the ECM. Any aftermarket “system” that deletes the factory air box will jeopardize the life of the ECM due to improper cooling. The ECM gets beyond hot to the touch when operating, and we are aware of several ECM’s that have failed due to insufficient cooling as a result of being relocated from the factory air box. A heat damaged ECM requires replacement and reprogramming by a dealership—a $1,700.00+ cost.
MAF Sensor Contamination. The MAF Sensor (Mass Air Flow) is the component which reads how much air is being drawn into the engine, and then relays that information to the ECM to match the proper amount of fuel to match the air volume. The MAF Sensor is a very sensitive and precise sensor. When an oiled-type aftermarket air filter is used, oil is drawn through the filter and into the intake system. This oil collects on the MAF Sensor, which will start to give an inaccurate reading, causing poor performance and reduced mileage. Eventually, the MAF Sensor will fail, causing a check engine light and required replacement of the MAF Sensor.
Tuki se mi zdi da zelo jasno piše zakaj ne menjat ''stock'' filtra za kerga kol druzga. Tako da ti priporočam da fustiš filter in in še ose ostalo kar je zraven njega, razen cevi. To cev bom pa tudi jaz uzel od Evolva, pa še nakaj stvari. Imam pa problem med izbiro zvoka izpuha od Evolva in BSR.
Krchan | 10 jul 2009, 15:50 | |
| Edino, kar ne bi delal od napisanega je DP in kat. DP je kar drag, brez kat. so pa problemi na tehničnem... Mogoče bi malo "odprl" zadnji lonec. Najbrž kakšno custom izvedbo by Lastovčič iz Samoborja (HR). Baje je kar strokovnjak, dela z dobrimi materiali, v dobro opremljeni delavnici in je cenovno ugoden. | Na vrh | |
Krchan | 10 jul 2009, 16:01 | |
Saj, ravno ECM in hlajenje le tega me skrbi. Edino če pri Evolvu nakladajo, da bi prodali svoje... @ Mihc, a veš ceno tiste cevi? | Na vrh | |
Volvo. 4 life | 10 jul 2009, 16:18 | |
| Kar se tiče čipanja, dobiš po pošti OBD kabel in pa cd, potem inštaliraš na laptopa in sam upgrejdaš svoj ECU, če se ne motim. Lahko pa se zapelješ do prve delavnice ki imajo OBD, in ti oni naložijo. Seveda lahko potem kadarkoli BP povrneš original nastavitve .... vendar vrjemi, tega si ne boš želel
Drugače ti bodo te stvari razložili preko mejla pri BSR, ali pa piše že na njihovi spletni strani, poglej malo... http://en.bsr.se/products/ppc/
čip te pride s poštnino 400€, mislim da je brezveze dat kakršnkoli €€ za drugo stvar, ki ti prinese 2 hp, ali 5 hp, ali pa 10 hp ... čip ti prinese realnih 40 hp in to je to
[ Uredi 10 jul 2009, 16:20 ] | Na vrh | |
Mihc V50 T5 | 10 jul 2009, 17:14 | |
| Zanimam se za čipanje pri SKN kjer tudi niso kaj preveč skopi z KM (HP), zanima me pa ali je izpuh kaj odvisen od čipanja ali pa druga turbina pa mogoče kak IC+ | Na vrh | |
Volvo. 4 life | 10 jul 2009, 17:23 | |
Da se ne bomo ves čas ponavljali glede " dodatnih " stvari ... VSAKA stvar je dobrodošla, bodisi svečke, filter, air intake,večji IC, izpuh, DP, ..... problem nastane pri čipanju! Čipi so pisani na Stage 0, kar pomeni stock.... to pomeni, da karkoli drugega menjaš, v čipu ne bo, razen če ti tuner tega update-a ne nudi! Sam sem poleg čipa menjal še polno stvari ki so mi pomagali na moči, vendar so si vsi tunerji enotni, da če bi naredil remap čipa, bi bil izkoristek lahko še večji!
Krchan | 08 nov 2009, 22:08 | |
| Nekaj novosti na mojem "rdečkotu".
Sem se odločil zamenjati navadne parkirne žarnice za bele LED.
Prej...
... in potem
Najprej me je razjezilo, da je ena res bela...
...ena pa modra
Nato pa sem ugotovil, da ko je motor prižgan utripajo!!! Se malo leva ugasne, nato malo desna itd. Malo sem še šaral po njih, vsako luč desetkrat dol in gor, pa ni nič boljše, tako da sem nato dal notri nazaj navadne rumene. A kdo ve zakaj se to dogaja. So problem "cheap" žarnice (eBAY cca 4 EUR) ali kaj drugega?
No, po tem neuspelem poskusu pa sem se spravil zamenjat "moosa". So bile že malo načete...
...tale losek pa je že toliko star, da mu je odpadel rog...
zato sem tudi preko eBaya (cca 6 EUR) nabavil nove, takšne, da jih ne bo vsak "poznavalec" avtomobilov zamenjal za Ferrarijeve.
AljAž | 08 nov 2009, 22:16 | |
| Preveč ga drgneš... | Na vrh | |
Krchan | 08 nov 2009, 22:21 | |
| AljAž je napisal(a): ... Preveč ga drgneš...
A ne vidiš da je usran ko prase...
@AljAž, kje si kupil LED-ke? So ti kaj "žmigale"?
[ Uredi 08 nov 2009, 22:31 ] | Na vrh | |
AljAž | 09 nov 2009, 18:17 | |
| Nič niso žmigale ipd. Kupil sem jih pa ravnotako na ebay.de, cena je bila podobna se mi zdi. | Na vrh | |
Mihc V50 T5 | 09 nov 2009, 20:01 | |
| Hej, samo res pride do izraza tako da če jih bo kdo naročal naj mi javi bi jih tudi jaz imel. Pa me zanima a je komu že kdo na tehničnih težil zaradi teh lučk?
doctor_v50 | 11 nov 2009, 20:39 | |
| jst sm jih kupu v A3M-u mislim da so iste samo so mi tut žmigale pa sm vn vrgu... | Na vrh | |
Krchan | 11 nov 2009, 21:18 | |
| doctor_v50 je napisal(a): ...
A zna kak električar razložit ta pojav in povedat če obstaja rešitev. Ali moraš samo imeti srečo pri nakupu LED-ic? Ker očitno enim dela, drugim pa ne. | Na vrh | |
urber | 11 nov 2009, 22:15 | |
| reds40t5 je napisal(a): ... doctor_v50 je napisal(a): ...
Nebe vedel, lahko da je res samo sreča Jaz sem jih kupil pri A3M-u, danes sem jih dobil po pošti in montiral, svetijo povsem vredu, le tako močna svetloba ni kot pri navadnih. Sem pa tudi objavil slikce, tako da lahko pogledaš. | Na vrh | |
Krchan | 16 nov 2009, 22:51 | |
| Danes premontiral gume (GY UG7+), kupljene lani, profila še 6mm. Letne sem pa zlizal čisto do konca, he he. So pa celo sezono "tulile", da so me vsi spraševali, če imam zanič ležaje. Sedaj je pa med vožnjo čisto tiho... Spomladi pa nekaj kvalitetnejšega na 17-colke. | Na vrh | |
Krchan | 22 dec 2009, 10:17 | |
| Narejen servis na 90.000km. Na zadnjih 20kkm mi je popil cca 8dcl olja Castrol 0W-30 for Volvo. Brez kakršnih koli težav in problemčkov (1x težava s ključavnico za vžig, po kakšni minuti je vžgal, se ne ponavlja več...). Zelo zadovoljen in še vedno navdušen nad avtom. | Na vrh | |
Sverige | 22 dec 2009, 10:21 | |
| Krchan je napisal(a): ... Danes premontiral gume (GY UG7+), kupljene lani, profila še 6mm. Letne sem pa zlizal čisto do konca, he he. So pa celo sezono "tulile", da so me vsi spraševali, če imam zanič ležaje. Sedaj je pa med vožnjo čisto tiho... Spomladi pa nekaj kvalitetnejšega na 17-colke.
Na Laguni sem imel Bridgestone Potenza, dve sezoni, pa so bile že zelo zlizane. Konec poletja sem montiral KUMHO SPT.... ne opazim razlike v obnašanju avta. Razlika v ceni je pa 30 EUR za eno gumo. Tako, da če nisi nek hud ekstremist za volanom lahko privarčuješ za dva mala servisa... | Na vrh | |
Krchan | 22 dec 2009, 13:11 | |
| Pri mojem vulkanizerju je 205/55-16 GY UG7+ cca 95 EUR, najcenejše pa ima Eskimo S3 in Kleber Krisalp za cca 75 EUR. Razlike je 80 EUR, kar ni nevem kaj veliko. Samo za 6l olja sem dal 105 EUR. Pa še vozim se v službo čez Gorjance, tko da na gumah ne gledam ravno na vsak evro. Pri nakupu pa tudi dokaj upoštevam ADAC-ov test, in GY UG7+ je že nekaj let v špici, čeprav se zavedam, da so vsaj tja do sredine lestvice razlike zanemarljive.
Sicer pa predvidevam da ger pri tebi za letne pnevmatike. | Na vrh | |
Sverige | 22 dec 2009, 13:29 | |
| Ja letne. Saj si napisal da daš spomladi 17" gor... Jaz imam tudi 17" letne. Tudi sam ne šparam pri olju in gumah, ampak gumo bi moral probat, bi videl da ni opazne razlike. Ne vem za druge Kumho gume, govorim za SPT, ki je njihova najboljša... | Na vrh | |
primzy69 | 24 jan 2010, 11:37 | |
| zelo lepa 40-ka! tele nalepke so pa res hude sploh dobr izpade k je avto rdeč
Krchan | 20 feb 2010, 10:44 | |
| Eno "površno" vprašanje za poznavalce. Danes na poti v službo se mi je na avtocesti na armaturki prižgal "info klicaj", na displejčku pa besedilo, od katerega sem si zapomnil samo nekaj podobnega kot "anhangersyst. bla bla bla...". Trajalo je samo nekaj sekund in se nato takoj ponovilo še dvakrat-trikrat. Ko sem končno našel mobitel, da bi slikal, pa se ni več pojavilo.
Moje znanje nemščine je slabo, mislim pa da "anhangerkuplung" pomeni vlečna kljuka. Mogoče povezava s tem, saj je kar močno padal dež, pa tudi kljuko imam na avtu (sicer ni namontirana), pa da bi prišlo do kakšnega stika?
drugače pa je med vožnjo vse normalno delovalo... | Na vrh | |
Krchan | 06 maj 2010, 22:39 | |
| Malo update-a!
Sem že čez 100.000 km...
Imam pa že nekaj časa tudi nove gume. Po daljši debati z "mojim" vulkanizerjem sem se odločil za Barum Bravuris 2, dimenzija je 225/45-17. Sam sem hotel dati gor sicer kakšno bolj zvenečo znamko, pa me je vulkanizer prepričal, pravi da tudi sam vozi na Barumu 200+HP avto, pa je enako zadovoljen kot s Continentalom in Bridgestonom. Oziroma je rekel tako: Ni Continental (108€) toliko boljši kot je Barum cenejši (80€ z montažo in centriranjem + novi ventilčki). Pa še Barum spada pod Conti koncern... Zaenkrat sem zadovoljen, saj je guma dosti boljša kot prejšnja Avon, ki sem jih dobil že na avtu. Sploh po mokrem.
Pa še načrti za bližnjo prihodnost: poliranje in globinsko čiščenje avtomobila in foto-shooting avta s "šolano" fotografinjo. Sam še dober plac je treba najdet...
[ Uredi 06 maj 2010, 22:40 ] | Na vrh | |
Krchan | 08 jul 2010, 22:28 | |
| He, he! Sem bil danes v Ljubljani s kolegom. Sva šla gor z mojim avtom, nazaj pa vsak s svojim...
Je S40 T5, Momentum, letnik 2004, slovenski, avtomatik, 113.000km, zelo lepo ohranjen...bom pa še probal nagovorit lastnika, da "odpre" svojo garažo na forumu. | Na vrh | |
Terminator | 08 jul 2010, 22:38 | |
| lepe fotke A to je ta k je biv na avto.net? | Na vrh | |
Krchan | 08 jul 2010, 22:59 | |
| Terminator je napisal(a): ... lepe fotke A to je ta k je biv na avto.net?
Jp! Trenutno je še... klik
Bivši lastnik pa je sin "taglavnga šefa" BTC-ja. Je dec v 14. dneh spustil ceno iz 13.750€ na ahhhh, raje ne povem ! Pač je blo preveč novih BMW-jev na dvorišču, pa je bil Volvo odveč! No, tle pa pol mi not vskočmo... | Na vrh | |
divja jaga | 08 jul 2010, 23:05 | |
| Krchan je napisal(a): ... Terminator je napisal(a): ... lepe fotke A to je ta k je biv na avto.net? Jp! Trenutno je še... klikBivši lastnik pa je sin "taglavnga šefa" BTC-ja. Je dec v 14. dneh spustil ceno iz 13.750€ na ahhhh, raje ne povem ! Pač je blo preveč novih BMW-jev na dvorišču, pa je bil Volvo odveč! No, tle pa pol mi not vskočmo... Super avto in super priložnost za privarčevat par €€ Sin za BMW-je, oče za Audija ( mislim, da ima gospod J. M. belo Q7 ) Denar je pri hiši, saj vidite kaj delajo s kristalko, 8-9 dni za etažo. | Na vrh | |
Krchan | 08 jul 2010, 23:14 | |
| divja jaga je napisal(a): ... Krchan je napisal(a): ... Terminator je napisal(a): ... lepe fotke A to je ta k je biv na avto.net? Jp! Trenutno je še... klikBivši lastnik pa je sin "taglavnga šefa" BTC-ja. Je dec v 14. dneh spustil ceno iz 13.750€ na ahhhh, raje ne povem ! Pač je blo preveč novih BMW-jev na dvorišču, pa je bil Volvo odveč! No, tle pa pol mi not vskočmo... Super avto in super priložnost za privarčevat par €€ Sin za BMW-je, oče za Audija ( mislim, da ima gospod J. M. belo Q7 ) Denar je pri hiši, saj vidite kaj delajo s kristalko, 8-9 dni za etažo.
Oče ima novo BMW 5 in 7, ter malo starejšega CLS. Lahko pa še kaj drugega, pa mi ni povedal. Nakup je bil pa res
divja jaga | 08 jul 2010, 23:20 | |
| Možno, jaz vem samo za Q7
No, važno, da je nakup volva bil | Na vrh | |
alfaromeo | 09 jul 2010, 08:42 | |
| Berem, da sta uredila tako kot je treba : cheers: | Na vrh | |
Gostov: 76, Članov: 0 ...
