http://www.vozimvolvo.si/
AWD in Volvo
Pojdi na stran  1 2 3 4 [5]
RollingStone
24 sep 2009, 11:46
Objav: 1965
Same delfino ima tudi samo 20hp, pa gre povsod. Pa ravnotako ne spada v to debato.
Švedmorebitprh
24 sep 2009, 13:13
Član #408
Prijavljen dne: 11 jul 2007, 12:55
Objav: 228
Pa zakaj pinca pa haflingerja s traktorjem primerjaš. Pinc gre 110 km/h in se z njim lahko 10 oseb komot pelje v največje klance.....to še Puch ne zmore.
tonkoexpress
28 sep 2009, 19:53
Član #21
Prijavljen dne: 12 nov 2006, 23:49
Lokacija: dolenc
Objav: 230
Od kdaj in pri katerih modelih oz. motorjih ima Volvo Instant Traction sistem?
Volvo. 4 life
22 dec 2009, 22:38
Član #384
Objav: 3327
AljAž je napisal(a): ...
"vklopljivi" pogoni so vsi haldex, visco itd.
How can Volvo claim they have full time AWD even though primarely only two wheels are powered?
The Volvo automatic AWD system has no traditional transfer case. Primary power goes to the front wheels. The rear drive shaft incorporates a viscous coupling (Haldex on the new XC-90) and as long as front and rear axles rotate at the same speed the coupling unit would remain inactive and the rear tires receive no torque - they are just rolling along. Would indeed slippage occur at the front wheels, the VC (Haldex) will create a power flow to the rear axle.
But if only the front is powered in no slip situations (which is almost always) and the rear does not get any torque - how can Volvo claim it to be an AWD system?
Surprisingly, if only one axle is powered, front and rear axles do not rotate at the same speed. The powered axle always spins a little faster (about 5%) than the axle with the wheels just rolling along. It slips a little on the ground. So, the VC (now Haldex) reacts to the speed difference and compensates with a proportional allocation of torque for the rear. This way the rear axle will get 5% of the torque and thus each rear wheel receives 2.5%.
Voila! All 4 wheels get power all the time. Volvo PR did not lie - it is full time AWD.
However, a power distribution of 95/5 makes for very insufficient traction use. The front axle is very likely to start spinning with the slightest change of traction. A power split of about 50/50 guarantees the safest use of available traction. After all that's the way 4WD was intended to be. Volvo does not offer that.
A serious drawback of the older Volvo system (Viscous Coupling) is, that you will probably have to buy four new tires if only one is bad.
Please note, that newer Volvos with Haldex couplings do not suffer damage when the tire sizes are slightly unequal.
AljAž
24 dec 2009, 17:29
Lokacija: nM
Objav: 3767
Voila odgovoril si sam sebi. Kaj ti pomaga "kao stalno vklopljen" awd če je končni rezultat praktično enak tistemu za katerega se pač "fabrški PR" ni spomnil da je "kao" stalni. Kolesa se vrtijo... v prazno.
Volvo. 4 life je napisal(a): ...
However, a power distribution of 95/5 makes for very insufficient traction use. The front axle is very likely to start spinning with the slightest change of traction. A power split of about 50/50 guarantees the safest use of available traction. After all that's the way 4WD was intended to be. Volvo does not offer that...
mrv
07 jun 2012, 09:49
Član #1416
Lokacija: poetovio
Objav: 1234
nekaj slik glede servisa AWD pogona pri 850 AWD in V70 PH1 verjetno tudi XC70
http://s79.photobucket.com/albums/j142/Bilderkammer/Volvo%20V70R%20AWD/Workshop%20Winkelgetriebe%202010/
[ Uredi 07 jun 2012, 09:52 ]
mrv
07 jun 2012, 09:58
Član #1416
Lokacija: poetovio
Objav: 1234
pa to če keri rabi
http://www.driveshaftparts.co.uk/index.php?searchStr=volvo+v70&_a=viewCat&Submit=Go
Na Ra ne paše ma večji zglob, cene pa so smešno ugodne
AssKicker
03 jan 2016, 12:13
Član #12712
Lokacija: Bled
Objav: 577
Meni se pa zdi da awd zelo hitro vklopi.. Danes sem malo sprobaval mojega V70 D5 awd ročni menjalnik, in se mi zaenkrat zdi super. Sicer z drugimi 4-kolesnimi pogoni niti nimam izkušenj, ampak kar sm se danes vozil pa igral, se je super obnesel
gorgh
03 jan 2016, 12:29
Član #3073
Lokacija: Škofja Loka
Objav: 758
Mene pa jebe in jezi ker mam kao 4wd avto, pa mi haldex ne dela, matr me jezi. Cakam mehankarja da ma cajt in se zrihta use nazaj u nulo pol nej pa suva ta sneg. Nism u lajfu se mel 4wd pa komi cakam ))
MarkoD
03 jan 2016, 12:32
Član #11880
Objav: 266
Jaz sem svojga dons parkrat "pritisnil" po zasneženi cesti. Je hotel zadnji del avta prehitevat
Tko da sklepam da vsi štirje vlečejo
Cojz
05 jan 2016, 19:47
Član #13401
Prijavljen dne: 16 dec 2015, 23:46
Lokacija: Štajerska
Objav: 79
Evo sem demonstriral AWD v v60
http://1drv.ms/1PL6NbO
http://1drv.ms/1O6ztaF
Gostov: 98, Članov: 0 ...
Člani: 6089
najnovejši član: AkiboxaNuM
