Side protect
lukanovak | 05 mar 2012, 16:05 | |
| Član #2569Prijavljen dne: 19 jan 2012, 17:35 Lokacija: Koper Objav: 137 | LP! Na mojem volvu sem ze ob nakupu opazil da ima side protect ampak nikjer ni bilo pametne razlage zanj, vem da je varnostna zascita ki sluzi v karambolu ampak me zanima kako to deluje, je to pena ki se razsiri cez cel vrata ali kaj drugega? | Na vrh | |
4volvo | 05 mar 2012, 16:10 | |
| "Safety was further improved on models from 1993 onward with the introduction of side-impact protection. This was virtually unheard of at the time, and was provided (again as standard) by the forerunner of the SIPS system used on all modern Volvo cars. The SRS (Supplemental Restraint System) system, which includes airbag, further uprated side impact protection and various hooks, straps and pulleys to secure items in the boot, also became available for the first time from 1994. UK models also included daytime running lights as standard although these could be disabled by the dealer at the owner's request."
Vir: http://en.wikipedia.org/wiki/Volvo_440/460#Safety | Na vrh | |
Damijan | 05 mar 2012, 20:32 | |
| SideImpactProtectionSistem prvič v seriji 850. To je samo zasnova in konstrukcija avtomobilske karoserije, kjer se sile pri bočnem trku razporedijo na večji del karoserije.
Je bila dobra slika v prodajnem katalogu od cegle 850. Mojega ima še vedno gospod precednik, pa mogoče poskenira tisto stran in jo nalima sem gor. | Na vrh | |
lukanovak | 05 mar 2012, 20:49 | |
| aha, samo v tapeti vrat je kot nek kvadrat z peno ali nekaj takega. mislim to sem js najdu v avtu. | Na vrh | |
bbf | 06 mar 2012, 09:37 | |
| pri 300 je v vratih cev, podobno kot na zgornji sliki una prečna pločevina. | Na vrh | |
lukanovak | 06 mar 2012, 09:42 | |
| js mam cev v avtu, varjanta kletka. mene zanima v tapeti vrat namescena pena, na kateri pise volvo side impact protection. bom slikal pa dal sem gor. vem da ima avto stange za sile da se razporedijo. mene znaima kako ta pena deluje, za ostalo vem. LP! | Na vrh | |
Gostov: 21, Članov: 0 ...
