DIY menjava akumulatorja V70 05
alkor | 06 okt 2011, 08:31 | |
| Član #72Prijavljen dne: 17 nov 2006, 20:38 Objav: 155 | Zivijo,
Je treba biti na kaj posebno pozoren pri menjavi akumulatorja na V70. Ali samo odvijem, zamenjam in privijem novega?
Hvala.
a | Na vrh | |
Ovlov | 06 okt 2011, 14:10 | |
| Upam, da bo tole OK:
Replacing the battery
Version A
· Switch off the ignition. · Wait at least 10 minutes after switching off the ignition before disconnecting the battery so that all information in the car's electrical system can be stored in the control modules. · Remove the bolts on the retaining bracket over the battery and lift out the bracket. · Disconnect the negative (ground) cable first. · Fold up the plastic cover over the positive battery terminal. · Disconnect the positive cable and lift off the plastic cover. · Pull the ventilation hose* from the battery. · Remove the bolt on the lower retaining bracket and remove the bracket. · Lift out the old battery and put a new one into place. · Put the lower retaining bracket in place and retighten the bolt. · Press the cover for the positive battery terminal into place. · Reconnect the positive cable. · Fold down the lid of the plastic cover over the positive terminal. · Connect the negative (ground) cable. · Be sure that the ventilation hose* is securely connected to the battery and that the other end of the hose is properly routed through the ventilation opening in the floor of the battery compartment. · Reinstall the retaining bracket over the battery and retighten the nuts.
Version B
· Switch off the ignition. · Unscrew the cover over the battery. Wait at least 10 minutes after switching off the ignition before disconnecting the battery so that all information in the car's electrical system can be stored in the control modules. · Disconnect the negative (ground) cable first. · Disconnect the positive cable and pull the ventilation hose* from the battery. · Remove the bolt on the lower retaining bracket and remove the bracket. · Lift out the old battery and put a new one into place. · Put the lower retaining bracket in place and retighten the bolt. · Connect the positive cable first. · Connect the negative (ground) cable. · Be sure that the ventilation hose* is securely connected to the battery and that the other end of the hose is properly routed through the ventilation opening in the floor of the battery compartment. · Reinstall the cover and screw it securely in place. NOTE: After the battery has been disconnected or replaced, lock and unlock the car with the central locking system's remote control to reactivate such features as the power windows, moonroof, courtesy lighting, etc.
[ Uredi 06 okt 2011, 14:12 ] | Na vrh | |
alkor | 06 okt 2011, 17:07 | |
| ma super. Hvala ti.
ales | Na vrh | |
Kelt | 06 okt 2011, 17:36 | |
| 10 minut za kopiranje podatkov!?! Kaj bo Nasin comp prekopiral? | Na vrh | |
urber | 06 okt 2011, 21:44 | |
| Ugasneš avto, odstraniš minus, plus, zamenjaš akumulator, gor plus nato minus in voziš. To je ta zakomplicirana zadeva. | Na vrh | |
Ovlov | 06 okt 2011, 21:53 | |
| Urber, kaj ko bi o svojem odkritju sporočil Švedom, da nam ne bi po nepotrebnem kradli čas?
[ Uredi 06 okt 2011, 22:44 ] | Na vrh | |
urber | 06 okt 2011, 23:02 | |
| Jah no, nevem če je to ravno odkritje, še na vseh vozilih/strojih sem tako menjal akumulator (med drugimi tudi na švedu S60) pa ni bilo problemov, mislim pa da si tudi večina mehanikov poslužuje podobne izvedbe Povsem pa razumem, da je uradni postopek do potankosti natančno opisan in malo bolj kompliciran. | Na vrh | |
Gostov: 70, Članov: 0 ...
