(V50, 2004) Reset servis lučke
dbiz | 24 sep 2008, 11:09 | |
| Član #694Prijavljen dne: 01 apr 2008, 12:01 Objav: 21 | ali mogoče kdo ve, kako se resetira servis lučka pri V50 2.4i, letnik 2004? a obstaja kaka kombinacija al je to možno le na servisu? hvala.
[ Uredi 24 sep 2008, 18:43 ] | Na vrh | |
dbiz | 24 sep 2008, 13:26 | |
| Član #694 Prijavljen dne: 01 apr 2008, 12:01 Objav: 21
| hvala.
dbiz | 25 sep 2008, 09:37 | |
| žal men to ne prime.... števec dnevnih kilometrov se sicer postavi na nulo, vendar nazaj ne gre... | Na vrh | |
AljAž | 25 sep 2008, 17:21 | |
| Pa si poizkusil vse naštete variante?? | Na vrh | |
SepoX | 25 sep 2008, 19:58 | |
| Evo, ker sem lep, sem ti skopiral iz VADISA za tvoj model.
Resetting the service reminder indicator (SRI)
Hint: The lamp can also be reset using VIDA vehicle communication.
The service reminder indicator (SRI) informs the driver that it is time for the vehicle to be serviced. The text message is displayed for 120 seconds each time the ignition is switched on.
Proceed as follows to reset the service reminder indicator (SRI): -Ignition position I
-Press and hold in the reset button for the trip odometer
-Ignition position II. Note! Turn the key to position II within 2 seconds.
-Hold the reset button for the trip odometer pressed in until the original value has been reset
-The information lamp lights when the reset button must be released
-Release the reset button for the trip odometer within 4 seconds. The instrument gives an audible signal when resetting has succeeded
-If the trip odometer is already reset, the reset button must be held in for a minimum of 10 seconds and a maximum of 14 seconds.
Note! If the reset button for the trip odometer is not released within 4 seconds, the service reminder indicator (SRI) is not reset.
Gostov: 64, Članov: 0 ...
