vozimvolvo.si :: Forumi :: Mali oglasi
P: 765 turbo po delih ..
Volvo. 4 life
30 okt 2019, 13:20 Predogled tiskanja
Član #384
Objav: 3327
Bi koga zanimala 765, komplet, lahko s papirji. B230FT, automatic, schiebedah, plin, l. 88.
Jaz bi vzel samo notranjost, sedeže in zadnjo klop. Ostalo vse ostane. Avto je načeloma vozen. Možnost registracije kot starodobnika.
Vse info na ZS
Opis stanja avta s strani lastnika:
the engine is ok now. The cylinder head was cracked. But I repaired the engine by installing a new used cylinder head. I replaced all the gaskets and the toothed belt and also regrinded the valves. After that the engine ran very well. so the engine itself is good and new overhauled.
The problem is that it doesn't start. It's from the electronics. A relay or the control unit does not work properly. It can also be that just any cable is not properly connected. Unfortunately I did not find the exact problem. In also the car has 3 places on the underbody where it has to be welded. So this are the Problems from the car.
Otherwise it is a really nice car.
The gas system is pretty new from 2015 and works very well.
PURPLE
19 nov 2019, 15:45
Član #12913
Prijavljen dne: 20 apr 2015, 12:44
Lokacija: Savinjska
Objav: 128
Zdaj je spustl ceno na 1600.
sebaveh
19 nov 2019, 19:20
Član #91
Prijavljen dne: 22 nov 2006, 19:08
Lokacija: Slovenska Bistrica
Objav: 1249
Če je problem samo to, da ne vžge - potem ga lahko zrihtamo! In magari prodamo za več...
Volvo. 4 life
26 nov 2019, 16:54
Član #384
Objav: 3327
Prodano.
Nisem jaz kupil.
Gostov: 19, Članov: 0 ...
Člani: 6088
najnovejši član: PamelaCak
