(V70) Oznake motornega olja
BlazK
27 okt 2009, 23:24 Predogled tiskanja
Član #1343
Prijavljen dne: 18 okt 2009, 21:14
Objav: 83
Ali sem naredil kaj narobe ker sem namesto ACEA A5/B5 vlil Castrol edge 0w-30 z oznakami ACEA A3/B3/B4.
Še tabela, v čem je razlika.
A1 Fuel economy petrol
A2 Standard performance level (now obsolete)
A3 High performance and/or extended drain
A4 Reserved for future use in certain direct injection engines
A5 Combines A1 fuel economy with A3 performance
B1 Fuel economy diesel
B2 Standard performance level (now obsolete)
B3 High performance and/or extended drain
B4 For direct injection car diesel engines
B5 Combines B1 fuel economy with B3/B4 performance
C1-04 Petrol and Light duty Diesel engines, based on A5/B5-04 low SAPS, two way catalyst compatible.
C2-04 Petrol and light duty Diesel engines, based on A5/B5-04 mid SAPS, two way catalyst compatible.
C3-04 Petrol and light duty Diesel engines, based on A5/B5-04 mid SAPS, two way catalyst compatible, Higher performance levels due to higher HTHS
A je A5 nadgrupa in ni panike ali pač..Se lahko vozim?
[ Uredi 28 okt 2009, 08:00 ]
Gostov: 50, Članov: 0 ...
Člani: 5975
najnovejši član: Dmhskcrob
