http://www.vozimvolvo.si/
Številka šasije
Pojdi na stran  [1] 2
Volvo. 4 life
17 jul 2007, 11:12 Predogled tiskanja
Član #384
Objav: 3327
Morda kdo ve KAJ in KJE se da ugotovit iz serijske št. šasije?
Hvala za odgovore!!
[ Uredi 17 jul 2007, 12:03 ]
RollingStone
17 jul 2007, 11:25
Objav: 1965
Neposredno se da ugotoviti model, letnico, motor.
Posredno se da ugotoviti kakšno opremo je imel nov avto, število lastnikov, kje in kaj je bilo popravljeno oz. servisirano,...
Volvo. 4 life
17 jul 2007, 13:09
Član #384
Objav: 3327
Posredno? a to pomeni, da kličeš od servisa do servisa in sprašuješ o vozilu na podlagi št. šasije?
RollingStone
17 jul 2007, 13:21
Objav: 1965
Lahko to, lahko pa si prodajalec in imaš dostop do podatkovne baze.
Majkl
17 jul 2007, 13:31
Član #359
Prijavljen dne: 05 jun 2007, 22:48
Objav: 346
Evo direkt iz VADISA! Kr neki stvari se da prebrat! Če se rabi za kateri drugi avto povej!
1Identification plate
2VIN plate
3Vehicle type
4Model year
3 = 2003
V70 CH 286000-
XC70 CH 95000-
S60 CH 235000-
4 = 2004
V70 CH 349000-
XC70 CH 123000-
S60 CH 315000-
5 = 2005
V70 CH 459000-
XC70 CH 173000-
S60 CH 425000-
5Factory code
6Chassis number
7Manufacturer code
8Vehicle type
S = V70,V70XC,XC70
J = V70 BI-FUEL
H = S60 BI-FUEL
R = S60
9Type
D = V70XC/XC70 ARMOURED
J = V70 AWD (USA)(CDN)
W = V70
U = V70 BI-FUEL LPG
V = V70 BI-FUEL CNG
Z = V70 XC,XC70
A = S60 ARMOURED
H = S60 AWD (USA)(CDN)
S = S60
U = S60 BI-FUEL LPG
V = S60 BI-FUEL CNG
10Engine type
32 = B5244SG
33 = B5244SG2
49 = B5204T5
52 = B5254T4
53 = B5234T3
54 = B5244T5
55 = B5244T4
57 = B5234T7
58 = B5244T3
59 = B5254T2
61 = B5244S
64 = B5244S6
65 = B5244S2
72 = D5252T MSA 15.8
74 = D5244T2
79 = D5244T
11Emission
3 = KOD: EM F1
0 = KOD: EM H1
B = KOD: EM X3
C = KOD: EM L3
D = KOD: EM L6
G = KOD: EM X1
H = KOD: EM X2
K = KOD: EM L4
L = KOD: EM L7
N = KOD: EM T1
P = KOD: EM T2
Q = KOD: EM T3
R = KOD: EM E1
T = KOD: EM T4
V = KOD: EM Z1
W = KOD: EM Z4
X = KOD: EM Z2
Y = KOD: EM Z3
9 = KOD: EM F2
0 = KOD: SULEV+
4 = KOD: EURO4
5 = KOD: EURO5
6 = KOD: EURO3Note
B = KOD: EM X3
ARABIEN
H = KOD: EM X2
(USA)(CDN)
V = KOD: EM Z1
(USA)(CDN)
Y = KOD: EM Z3
(USA)(CDN)
12Gearbox
EXC (USA)(CDN)
2 = M56 manual gearbox
3 = M58 manual gearbox
4 = M66 manual gearbox
7 = AW50AWD automatic gearbox
9 = AW55-50SN automatic gearboxNote
*) Inspection number, for (USA)(CDN) and MC
43 only, Calculated from the VIN-code.
Check figure
(USA)(CDN)
13Model year
3 = 2003
4 = 2004
5 = 2005
14Factory code
15Chassis number
16Market code
17Interior fitting code
18Paint code suff.not prov.in the cat.
19Special vehicle number
20Spring front
21Shock absorbers front
22Stabilizer bar front
23Spring rear
24Shock absorbers rear
25Stabilizer bar rear
26Helper spring bump rubber front
27Helper spring bump rubber rear
Volvo. 4 life
17 jul 2007, 15:12
Član #384
Objav: 3327
Na voljo vam dajem številko šasije, če bi komurkoli uspeli karkoli zvedeti o avtu, bi bilo v veliko pomoč, hvala vsem!!
ST. SASIJE: YV1SZ799741151097
Poskusil bom še s št. prometne, sam je bil 1. poizkus neuspešen
volvo5er
17 jul 2007, 15:16
Prijavljen dne: 12 nov 2006, 21:24
Lokacija: Ljubljana Bežigrad
Objav: 1142
Neposredne ugotovitve iz vadisa: XC70 letnik 2004, D5, avtomatik.
Volvo. 4 life
17 jul 2007, 16:09
Član #384
Objav: 3327
http://www.avto.net/2004/osebna/oglas.asp?id=1121157#
avto je ta
volvo5er
17 jul 2007, 17:12
Objav: 1142
V 70 AWD je napisal(a): ...
avto je ta
:S:S
ali je napaka v vadisu, ali si dal napačno številko šasije, ali pa se je s tem vozilom svašta dogajalo.
Majkl
17 jul 2007, 17:14
Član #359
Objav: 346
volvo5er je napisal(a): ...
Res je! Če je res VIN prepisan iz prometne je neki zlo narobe! Moje mnenje, ne kupuj!
Sam to nemore bit, neki si zamešu oz so oni! Če si pa z avta prepisu pol pa
Volvo. 4 life
17 jul 2007, 17:26
Član #384
Objav: 3327
Ne vem, oni majo sicer tam še ene dva XC-ja pa baje sta dizla, tko da pomojem je tip zamešou VIN, ne morš vrjet, zdej mu pa ne bom še enkrt pisov, ker mi je že to komej poslov, tko da če ga bom šu pogledat, bom direkt z avta, pa sporočim!
Volvo. 4 life
17 jul 2007, 17:32
Član #384
Objav: 3327
Mogoče je tale:
http://www.avto.net/2004/osebna/oglas.asp?id=1442257
Volvo. 4 life
17 jul 2007, 17:47
Član #384
Objav: 3327
A mogoče kdo ve kako prodajalec dokaže da je 2. lastnik?
Dons se da pogledat na internet pa to ja, kaj pa še par let nazaj al pa včasih ko tehnologije ni bilo???
Volvo. 4 life
17 jul 2007, 17:51
Član #384
Objav: 3327
:S
ali je napaka v vadisu, ali si dal napačno številko šasije...............................................
..................... ali pa se je s tem vozilom svašta dogajalo.
LOL:)
Majkl
17 jul 2007, 17:58
Član #359
Objav: 346
Obstajajo evidence useh registriranih vozil(na UE), kako je pa z vozili iz tujine pa nevem! Če poznaš kirga policaja ti on lohk pogleda kolk lastnikov je vozilo menjalo(v slo) če je bil udeležen v prometni nesreči (v slo pa še obravnavana je mogla bit...)
Da se, neki, ne pa use...! (ku pr ženski, neki veš neki ne in učasih je bol tko ;) !
volvo5er
17 jul 2007, 19:18
Objav: 1142
http://e-uprava.gov.si/e-uprava/emrvl.euprava
kar se Slovenije tiče.
Majkl
17 jul 2007, 20:14
Član #359
Objav: 346
Sam za prometne nesreče pa še zmiri rabš policaja...
Volvo. 4 life
18 jul 2007, 09:20
Član #384
Objav: 3327
Evo, zdej se mi je opraviču da se je zmotu, tko da:
YV1SZ58K311017933
... to more neki smrdet...!!
Pravljicar
18 jul 2007, 10:21
Član #327
Prijavljen dne: 12 maj 2007, 11:29
Objav: 20
Ne da se dokazat pod nobenim pogojem !!!! Kaj pa če je avto uvožen ti nobena tehnologija ne pomaga. Zato te prosim da ne nasedaš bučkam. Meni grejo kocine pokonci ko na netu vidiš avto iz tujine in piše 1 lastnik. Vprašam ga po zdravju ? in naj mi dokaže da je prvi lastnik, samo iz katerih papirjev pa ?
potem pa se zgodba konča
volvo5er
18 jul 2007, 13:24
Objav: 1142
YV1SZ58K311017933
Ja tale pa je XC70 bencinar, letnik 2001 z ročnim menjalnikom.
Majkl
18 jul 2007, 14:48
Član #359
Objav: 346
YV1SZ58K311017933
IMHO:
Pomoje se neki resn prodajalec nebi smel kr neki motit in napačne cifre dajat...!? Nek razlog ziher je da se je zmotu! Če se boš odloču za nakup tega avta ga peli na original servis pregledat(oz prašej če so za, pa če je use ok ti plačaš stroše in kupiš avto če ne pa oni plačajo, itak so lastniki...), pa če nebojo hotli pol neki ni uredu!
PS Ko sm sam kupoval mojo 40ko sem lastnika prašal če se strinja da ga odpeljem na AMZS na preventivnega, pa ni bil glih za akcijo, oz sploh ni hotu slišat nič o tem, danes 3leta po tistem in porabljenih € za popravila v vrednosti avta, vem zakaj...! Tko da prvi indic da je neki narobe je že nestrinjanje z pregledom!
Šnavci
19 jul 2007, 11:55
Član #414
Prijavljen dne: 16 jul 2007, 12:28
Objav: 24
Sm delo v avtotrgovini, vem kak je to... Pač pri vseh teh avtih lahk tut po pomoti vzameš narobe prometno za tako manj pomembno stvar, kot je, da javiš šasijo enmu kupcu, ki je zgolj potencialni kupec... Na preglede se pa ponavadi da avto pelat, če stroške krije kupec, ker to ni v prodajalčevem interesu. To je pač zato, ker vsak dan pride gledat avte 100 ljudi in vsak po svoje palamudi naokoli, in pol ko ti en začne komplicirat, je treba pač stvari vzet čimbolj flegmatično.
Uff... sorry za offtopic.
Volvo. 4 life
19 jul 2007, 12:04
Član #384
Objav: 3327
Drgač ni glih tko.
če, bi se prodajalec že 1 let nazaj ko je začel prodajat ta avto, pozanimal oz. pridobil od pooblaščenega servisa potrdilo pregleda na testerju, da so kilometri realni, da bi pripravil vse račune od servisov od avta, v glavnem VSE kar spada k " prodajanju " avta in dal to lepo v eno mapco, bi lahko vsakič ko pride potencialen ali pa nepotencialen kupec, mu lahko dal lepo v roke, pa mu še ust ni treba odpret!!!
Ko sem jest prodajal svoj avto, sem že v štartu vse na avto netu napisov, mel v telefonu sms - že napisan in mejl sem tud že mel napisan, ampak ne 2 stavka, ampak, ne vem, stran ali 2!!
Drgač je blo pa v časopisu kakšn mesec nazaj, ko je en tip s FUL keša, se odpravu kupt avto, napravu se je pa ful po kmečk in hodu od trgovine do trgovine in ga ne vem v kolkih trgovinah niso sploh pogledal, kaj še prašal kaj hoče, na konc je pa kupu avto v neki trgovini, k so z njem delal kot ( npr. v Dumidi ), in je tam tut avto kupu, pol pa celo zgodbo objavu v časopisih......
...tko da, tko k si ti zgorej napisov, se ne dela, oz. se ni za zgledovat!
Sory
Lp!
AljAž
19 jul 2007, 12:24
Lokacija: nM
Objav: 3767
No fantje, dovolj OffTopic.
janp
18 feb 2009, 10:35
Član #1038
Prijavljen dne: 18 feb 2009, 10:22
Objav: 5
zdravo!
sem nov na forumu in upam da kmalu lastnik enega V70 tdi.
prodajalec mi je dal številko vin: yv1w7202y1002369
ima kdo možnost preveriti kaj se da zvedet o tem avtu.
je bil pa kakšno leto nazaj kupljen v trstu v salonu in tudi servisi naj bi bili delani tam, vslov. ga pa latsnik sploh ni še registriral, kar mi je malo čudno, za letnik 2000 ima kao samo 145000 km, cena pa 5900eu, kar je med najmanjšimi na avto.net...
baje ga je treba "samo" zavarovat in registrirat...
hvala za vse informacije in lep pozdrav
jan
volvo5er
18 feb 2009, 10:48
Objav: 1142
Dobrodošel na forumu!
Za začetek popravi VIN številko (je napačna, manjka en znak)
P.S. verjetno si pozabil črko S: je tako prav: YV1SW7202Y1002369 ??
[ Uredi 18 feb 2009, 10:55 ]
janp
18 feb 2009, 13:14
Član #1038
Objav: 5
ja ta bo prava s s-jem.
hvala
djsly9
18 feb 2009, 15:08
Član #945
Prijavljen dne: 24 nov 2008, 14:37
Objav: 15
v vadisu samo podatki da gre za V70, letnik 00
Engine: D5252T MSA 15.8
Transmition: M56
Ostalega moja verzija nima.
janp
22 feb 2009, 10:33
Član #1038
Objav: 5
hvala za informacijo in lp
Volvo. 4 life
26 maj 2009, 08:26
Član #384
Objav: 3327
YV1745872L2269551
Lahko še kdo pogleda, Vadis za tale VIN pokaže samo leto izdelave in naziv vozila
supr
26 maj 2009, 12:05
Član #862
Prijavljen dne: 25 avg 2008, 23:30
Lokacija: Slovenia
Objav: 167
Če pokličete na Dumido in zrecitirate VIN številko, vam (po mojih izkušnjah) povedo celotno zgodovino avta, v kolikor jo imajo.
Pa tudi ostali trgovci/serviserji bi vam znali to povedat, vendar z ostalimi nimam izkušenj glede tega.
Gostov: 41, Članov: 0 ...
Člani: 5976
najnovejši član: Juliovioky
